02-06-2014 01:36 AM
Hi
I have a ring structure in which i am loading a string array of four variables and its property is strings[]
but while i run the code it is showing only first value
on mouse down nothing is getting changed
on click on ring all values must be shown
02-06-2014 02:35 AM
Your ring is an indicator. Make it a control of you want to be able to operate it at run time. (right-click ...change to control)
02-06-2014 02:39 AM
Thanks for the solution. It works
