revert 8.6 to 8.5
Would someone be kind enough to revert the attached example vi from version 8.6 to 8.5? Thanks.
(2,377 Views)
Attached in 8.5.
WARNING: The VI uses Search 1D Array with the input array and the search element being a DBL. This is inherently flawed because it is not correct to perform an equality operation on floating point numbers. This issue has been discussed ad infinitum in this forum.
(2,364 Views)
