reverse program of application (EXE)
I would like to know about the program security in LabVIEW. In project explorer, we can make the program automatically run by create a standalone program using create application (EXE). How about if i have the application program taken by someone, then he want to edit the block diagram or  front panel of the program. Is it possible to do that or can LabVIEW reverse the application (EXE) back to normal VI or with password protected? Or it really cannot simply reverse the process.
mfaz
CAIRO
(3,321 Views)
Accepted by suffyzull
No, you cannot take an .exe program and turn it back into the source code VI's.
(3,313 Views)
Raven's post is correct, if you make sure to remove the BD's from the VIs in the exe-build (this is the default setting)
Ton
My LabVIEW Ideas
(3,294 Views)
