retrieve case values from case structure
I have a case structure in a state machine with a string input. Is there a way to retrieve the strings of all the case structure values?
For example, if the case structure has three states: "Init", "Run", "Shutdown". I would like to programmatically look at the case structure and return a string array with the three case values.
(2,699 Views)
You will need scripting to get at the strings associated with each of the states of a case structure.
Now if it was an enum instead of string... that would be easy.
Ben
(2,694 Views)
Here is a way to do it with out strings. I use an Enumerated value. If you hook it up to a case structure and have it add a case for every value then you see the steps. The enumerated value is a strict type def so that if you add a states all you have to do is have the case structure add a case for every value.
Tim
GHSP
(2,683 Views)
