resize tool get image size
I wonder how I can resize the image on labview vision so that the image does not lose much quality.
and also I wonder if it is possible to cut part of the picture and takes her image with some tool?
How do I use the tool "getimagesize" to enlarge the image?
Thank You.
Eliel
(2,779 Views)
I'm using the example "Example Magic Wand" to do a job.
I can, using the tool "IMAQ Select Line" to measure the size of a row but what I need is to use the "LINE" directly from the frame where the image is, would this be possible?
And when I click with the tool "Click" it selects a portion of the image and already opened the window so I can draw the line and I've put all the information.
So I want to use the "Line" to draw the line and measure the size and use the "Point" to select the regions with the tool "Magic Wand".
If this is not possible, would use the "Select Line" in the same window where the image is without opening another to draw the line?
(2,772 Views)
Olá Eliel,
Gostaria de te ajudar, porém não consegui entender exatamente o que você deseja.
Se você ainda estiver precisando de ajuda nessa aplicação, você poderia me explicar melhor o que você deseja?
Sinta-se à vontade em escrever em português.
Plínio Costa
Application Engineering
National Instruments Brazil
Plínio Costa
Senior Techinical Support Engineer
(2,699 Views)
