resize BMP
Hello I need a VI which resizes an importet BMP so that it fits into the picture-VI of the Front-Panel.
Can somebody help me?
Thx
Simon
Using Labview 7.1
Message 1 of 9
(5,740 Views)
Hi Simon,
I made this VI a while ago to reshape image files.
I hope it will help you 😉
Epictetus
Antoine Chalons
Message 2 of 9
(5,741 Views)
Thank, but unfortunatly there are some subVIs missing!
Using Labview 7.1
Message 3 of 9
(5,735 Views)
I agree that is a good program Titou,
But I guess your VI uses IMAQ functions.
So if you do not have IMAQ on your system, this would be a setback
Simon, In case you do not have IMAQ,  using the property 'Zoom factor' for a picture control/ Indicator Property Node, will help you achieve what you want.
Go to LabVIEW examples and find this VI: "Picture Control - Zoom Attribute.vi"
Also you can read the front panel window bounds ( using a VI property Node as shown in the pic) and work out a relation for the zoom factor of your pic
Message 4 of 9
(5,730 Views)
Oh.. Smiley Surprised then that means you don't have IMAQ vision installed...
Hummm there is certainly a way to do the same with picture functions... Have you tried to search, "resize image", or resample ?
I'm almost sure some example VI were posted on the forums...
Good luck
Epictetus
Antoine Chalons
Message 5 of 9
(5,729 Views)
Try this VI read_bmp_5.vi
Epictetus
Antoine Chalons
Message 6 of 9
(5,723 Views)
can't open it! got lv 7
Using Labview 7.1
Message 7 of 9
(5,718 Views)
Try looking at reply #7 in that thread.
___________________
Try to take over the world!
Message 8 of 9
(5,714 Views)
yeaaah!
thany you very much
Using Labview 7.1
Message 9 of 9
(5,707 Views)
