resetting elapsed timer
Hello everyone,
I am working on a temperature application. I am taking thermocouple reading from a FP-TC-120 device.
I want the thermocouple reading to stay within 1 degree accuracy range, say for 10 minutes. To do that I have written the attached VI. (Required temperature value and time target are inputs to the VI.) The problem is I want the elapsed time to be reset when the temperature value falls out of range. In the application I have written it reset no matter what the thermocouple reading is. Does the problem have something to do with the case structure? (I tried to use while loop but I had trouble with getting the thermocouple reading inside of the loop)
Deniz
(3,311 Views)
Accepted by deniz
The way you have it, the timer resets whenever the front panel boolean is true. You have absolutely no relationship to the thermocouple reading being in range or not. A simple fix is shown below.
Message Edited by Dennis Knutson on 04-29-2009 10:31 AM
(3,302 Views)
