reset x scale on waveform chart?
This is going to seem like a stupid question and I know that in order to reset the x scale for the waveform chart I need to create a property node and wire a array constant to the history node.  However it will not let me create this constant and even when I try to manually create it, I dont know how to get it into the waveform[dbl] format that it says my chart is in.  Maybe this is a simple fix, but being fairly new to this I am probably overlooking something.
I have attatched the code, it is for 7.1, and I did not write it, just trying to modify it.
Ryan
(2,260 Views)
(2,253 Views)
