reset switch automatically
hi
i have switch button in my front panel and its type is switch when pressed.
i want to reset this switch to False if some condition is true like if the output of an and gate is true .
after that the user can control it normally.
Message 1 of 8
(7,257 Views)
Do you want to reset it straight away, or some time later?
edit: What I mean is, will the "other condition" happen at any time, or will it only be before you switch it?
Message 2 of 8
(7,256 Views)
i want to reset straight away
i have this button in a loop
so if the action is true it will reset the button
and in the next iteration the user can control the button to switch it on or off .
Message 3 of 8
(7,251 Views)
Accepted by duaa
You can use something called a Property Node to set the value of a Control or Indicator somewhere else in a program.
To create a property node for your button, right-click the terminal for the button in the block diagram and choose Create >> Property Node >> Value. Then, you'll have your property node and can place it anywhere on the block diagram. It probably defaults to "Read", but just right-click the property node and choose "Change to Write," and now you will be able to write a value to it. Use a case structure to decide whether or not to write the value based on some other condition.
Ravi A.
National Instruments | Applications Engineer
Message 4 of 8
(7,225 Views)
If you don't want the user to have access to the button until it is reset, you can also use the "disabled" property node to control access to the button during certain conditions.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 5 of 8
(7,219 Views)
Ravi Antani))
i did this , i add a propery node and value type ,then write false to the switch when some condition is true and this is in case structure . but the problem after that the switch is disabled and i cant control it again in the front panel ? !
i want something to reset the switch and after that the user can control it and it is not disabled .
here is a screen shot fro my program
Message 6 of 8
(7,205 Views)
ok the problem is solved Smiley Happy
it was a programming problem since i was using formula node
thank you all 🙂
Message 7 of 8
(7,202 Views)
Your conclusion makes no sense.
First, the Value property node has nothing to do with whether a control is disabled or not.  The Disabled property node handles that.
I don't know what programming problem in your property node would cause that.
I don't think you should be using a property node at all.  The code in there looks like you should be able to implement it using a handful of basic LabVIEW functions.
Message 8 of 8
(7,195 Views)
