reset graph
hello,i have the next code in labview and i would like to reset the values of the graphs when the code is executed again.
i did it with a history data reset to values equal to 0,but the graph is rested after the first iteration of the bucle while,so i am lossing the first value of the graph,because the first value represented is the second.
how could i solve this problem?
thanks
(2,717 Views)
Accepted by mariomoskis
If you just do this :
It should work better, if there is no dependency between the while loop and the property nodes that reset your graphs' history then LabVIEW can "decide" to do which ever it wants first, if there is a dependency (a wire for instance) it will force LabVIEW to execute the property node first and then the loop.
Hope this help
Epictetus
Antoine Chalons
(2,713 Views)
