report generation toolkit VI error when running EXE
A VI inside the Report Generation Toolkit (version 1.1.2), Excel Find Application Directory.vi, will not function correctly when running an EXE.  The "Current VI's path" block will return the path of the currently running EXE rather than the path of the Excel Find Application Directory VI.  (The same would be true for Word Find Application Directory.vi.)
-Joel
(4,223 Views)
Do you get error7 ?
Christian
(4,206 Views)
Yes, error = 7
(4,196 Views)
Accepted by Snood1
Have you had a look at this knowledgebase article? The error is caused due to the exclusion of any dynamic VI.
Ipshita C.
Applications Engineer
(4,176 Views)
Thanks!  I had heard rumors of this KB article that explains how to solve my problem, but had been unable to locate it.
(4,158 Views)
