report generation in windows
Hi There,
When i am using report generation in my mac it is working fine but when i make an exe file of my vi and use it on windows report generation is not working. Is there a way to save the report in a file or see it as html in browser in windows. I understand there is a report generation toolkit for office, does i need to have that to just use report to save in a file or see in a html browser in windows
Yogesh
Message 1 of 11
(4,376 Views)
you can use the new report.vi and than create a constant on the report type and than from there you can ppend front panel images or anything else you want to go to an HTML
also there is a section called HTML reports only
hope this helped
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 11
(4,364 Views)
Hi Harold,
I used new report.vi and transferring some data to the report. It works fine in mac, but when i use it on windows and run the vi to generate report, it does not do anything.
On my windows i just have run time for labview.
Yogesh
Message 3 of 11
(4,358 Views)
So,
You create an application on a Mac (presumably for a Mac?) and distribute it to a PC and it does not work?  How awful! Uhmmm.. hmhm..psst!
What LabVIEW version is installed on your MAC and witch license?
"Should be" isn't "Is" -Jay
Message 4 of 11
(4,354 Views)
Labview 8.2 and about i assume basic license.
Message 5 of 11
(4,348 Views)
You cannot run a MAC application on a WINDOWS machine. You have to recompile the VI and build a new application for Windows on a Windows machine (which means you need the Windows version of LabVIEW to recompile and create the Windows version of the application).
You seem to be using some subVI to get a path. I'd also guess that whatever you have in there is probably Mac-specific.
Message Edited by smercurio_fc on 08-06-2009 04:26 PM
Message 6 of 11
(4,332 Views)
I have a basic version of Labview 8.2 for windows also. I am making .exe file using that. Everything else works fine in windows except report generation. Even when i run a vi in windows Labview 8.2, i am still not able to print report on browser or save report in a file. I said that i have runtime for windows because eventually i have to run it in a windows computer with runtime version of labview only. But for making the installer or .exe file i am using Labview 8.2 basic windows version.
Message 7 of 11
(4,325 Views)
Accepted by topic author Yogesh9ic
Have you tried the shipping examples? Like the "Example HTML Report" VI?
Message 8 of 11
(4,322 Views)
Thanks for your help. The example help. Now i can able to generate report as html and can see in browser. But i still not able to save the report in a file.
Yogesh
Message 9 of 11
(4,305 Views)
Is there a way to save report as text file or spreadsheet file. I can able to save it as html file. Anyway that is not a big deal because i can see and print report in browser.
Message 10 of 11
(4,304 Views)
