replacing files & for-loops
Hallo,
I have a little problem with writing files, whose name is generated by a for-loop. Their names are mess0001.txt, mess0002.txt etc. At the end of the jiip the variable [i] falls back to 1 and the VI asks me if it can replace the file mess0001.txt. The new file and the overwritten file contain the same data. How can I prevent that?
I prefer something like: If file exists then exit program.
Arno
(2,592 Views)
Wire the desired path to "file info.vi" (advanced file palette) and wire the error cluster ot a case structure. If no error occurs, the file exists and you can exit. If an error occurs, continue.
You could also list the files (list directory.vi with e.g. pattern "mess*.txt"), extract the numbers from the list of file names and continue with a file name using "highest number+1").
(2,592 Views)
