Is it possible to create virtual devices with the MAX, so that I can write and test my LabVIEW programs on another PC than the one used for the application? (I can't access that one via LAN) Thanks for your help! Karin
If your device is an instrument that uses an IVI driver, then you can use the simulation mode of the driver. If it's not, then you'll have to modify your program to skip over any calls to the hardware and return simulated data.
