replace single character and leave the ones in expressions
I'm looking for nice and elegant solution to my problem. Let's say I have a string "e+exp(e)". I want to replace all "e" with "1", excepts the one in "exp". I was trying to use regular expressions but I've failed after an hour... The solution should be able to solve things like replace "a" in "rand(a)" without changing rand. Basically I need to replace single character without replacing the ones in words/expressions.
Any ideas?
(3,272 Views)
Accepted by pitol
No time for elegance right now, just brute force.  I would pad the string with spaces on each end to remove end cases and then search for the character surrounded by non-word characters.
Message Edited by Darin.K on 04-14-2010 04:06 PM
(3,259 Views)
Thanks! After looking at your solutions I must say that I was pretty close trying to solve it myself. Can you explain how those $1 and $2 works, that you put in replace char?
(3,233 Views)
If you look in the regular expression you will notice two expressions in parentheses, these are called capture groups.  In this case each one captures a non-word character.  To put those characters back in I put $1 and $2 into the replace string.  $n refers to the nth capture group inside the regex (comes from PERL so start counting at 1).  Very handy when you are looking to rearrange a string.
(3,209 Views)
Thanks again! It is indeed very handy 🙂
(3,188 Views)
