replace object
I have got a vi that programmatically replace an object (control) on the FP
with another object(control) using the
Control Invoke Method : Replace. When I try writing the same vi myself I
get the Control Invoke Node, but can not access Replace option. I'm working
with LV8. Does anybody can help me.
Thanks in advance,
Alexander.
(2,737 Views)
If I remember correctly, the replace method is a scripting method and is not supported officially by NI. In LV8 NI put the scripting capabilities behind the license engine so you can't get to them. There are workarounds (see the LAVA forums), but I would suggest that you consider whether you really want to use this method. If you describe what you want to do there might be an alternative way.
___________________
Try to take over the world!
(2,719 Views)
