replace files in installer
I am looking for a possiblity to change file (e.g. configuration oder documentation files) in an already build installer sw.
history:
we use the same labview program for differnet projects and the folks who make the project configuration don´t use labview.
At the moment I allways must  build a new installer.
aim:
the project folks only change the configuration and documantation files in the existing installer and bruning a setup cd.
Is there a way?
jan
(3,131 Views)
Hello Jan,
our installer is based on the MSI from MS, this programm is converting all necessary files in a *.msi files. These files are not directly editable, therefore you need to create the installer again (from LV).
regards,
Tobias
(3,084 Views)
I have the same question. Is this still the same after 7 years?
(I want to replace a certain *.xml file that is used during runtime in my installer and literraly only one character is changed)
(2,794 Views)
