replace characters in string
Hello everyone,
Is there any way to index the characters in a string as if it were an array and remove them starting from the second position and on. I just want to end up with the first letter or number so that I can later concatenate strings to it.
Thank you for any help!
-Michael
(7,395 Views)
Accepted by topic author MichaelHadrien
Hi Michael,
Yes. Use the "Sring Subset" function. Set the start to 0 (default) and the length to 1.
This will give you the first character of the string.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(7,391 Views)
thank you steve!
(7,387 Views)
