replace array subset
I have a problem that I can't seem to solve.  I have a array of 6 valves that are a type def.  I want to be able to indicate which ones are on using a for loop.  The for loop count terminal is wired to the number of valves that are being tested.  I expected indicators 1-5 to turn on in the example, but only 5 shows on.  Can you tell me what I am doing wrong?
I just figured it out, sorry to bother you.  I changed the input tunnel to a shift register and left the output tunnel as last value still connected to the valve indicator.
Thanks.
metzler CLAD
(4,967 Views)
You need to use a shift register.  Without it, your iteration 1-4 does nothing and the data is disregarded.
(4,953 Views)
Also is there a reason you want to wait 500ms between each replace?  And did you know you can do this without a for loop?  Attached is an example.
(4,951 Views)
The delay was inserted just so I could see what was happening a little slower (was originally 1000ms) with highlight execution.
I don't think your diagram without the for loop will work - the original valves all start with the indicator status off.  This is part of a state machine that tests up to six valves.  The count terminal of the for loop is used to iterate the loop the number of times depending on the number of valves being tested.
Thanks for the feedback, Hooovahh.
metzler CLAD
(4,938 Views)
Accepted by metzler
metzler wrote:  I don't think your diagram without the for loop will work - the original valves all start with the indicator status off.  This is part of a state machine that tests up to six valves.  The count terminal of the for loop is used to iterate the loop the number of times depending on the number of valves being tested.
Then use Initialize Array.
(4,922 Views)
Oh right, either initalize as mentioned, or what I should have done is set the control to 6 falses then right click Data Operation  >> Make Current Values Default, and saved the VI.
(4,883 Views)
