replace 1d array at specific point in 2D array
I have a 2D array with alot of information and only want to replace some data at a specific point... see image:Schermafdruk 2014-08-26 09.53.17.png
When i use replace subset i can only replace one element at a specific row and column...
Thijs Boeree
Message 1 of 8
(6,415 Views)
So, use a loop. 😄
Message 2 of 8
(6,410 Views)
Accepted by topic author ThijsBoeree
I think i allready got it... Without a loop!!
I use index array on the 2D array then i use replace array subset on the 1D array, here you can give an index and replace the 2D array again with the newly formed 1D array!
Message 3 of 8
(6,402 Views)
Hi Thijs,
yes, without a loop - but with a data copy in memory…
Programming such algorithms always has to consider more than just one parameter/side effect/limitation: computing speed, memory footprint, …
Message 4 of 8
(6,387 Views)
The correct solution is to change the small 1D array to a 2D array and use "replace array subset" with both indices wired.
It requires a 2D array such that the function know if it needs to replace going down or going right from the given index. It cannot deal with a 1D array directly, because the operation would be ambiguous.
Message 5 of 8
(6,351 Views)
Here's what I had in mind.
(If you want to replace down the column instead, simply add a transpose after the build array node.)
Message 6 of 8
(6,343 Views)
Message 7 of 8
(6,335 Views)
Wow that's a much nicer approach!
Thijs
Message 8 of 8
(6,298 Views)
