repeat array several times
hi all,
how to repeat array several times like [ 1 2 3 4 ] to [ 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 ......]
i know it's so simple because i'm new on labview
(6,540 Views)
Several options here.
1) Build Array - It is expandable.  Just extend it to the number of times you want to repeat your array.  Right-click on the Build Array to make sure it is set to Cancatinate.
2) Use a FOR loop with a Cancatinating output tunnel.  Make sure the input tunnel is not set to autoindexing.  You then just set N to be the number of times you want your array repeated.
(6,535 Views)
Here is how it can be done.  Using 2012 and newer there is new for loop terminal functions that make it easier.
If you want more free training on LabVIEW check out some of these links.
NI Learning Center
NI Getting Started
-Hardware Basics
-LabVEW Basics
-DAQ Application Tutorials
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
EDIT:  This is what Crossrulz described
(6,531 Views)
