renaming DAQmx event
hey guys,
Im trying to get the event name in the handler to be something useable instead of "task out". I found a post on the forums that said to create a sub vi and run the reference through there so you can rename the output driving the Reg Events structure. This didnt seem to work, im going to post what I have, maybe I did it wrong.
(3,389 Views)
Accepted by topic author pathare535
Problem is event with details is stored in hidden params of indicator refnum
Check whether event refnum has been updated in sub-vi - it shows name in context help window
If not, expand, contract event node.
Then recreate indicator
Reconnect main.vi
Press Run button with ctrl to force it recompile main.vi
(3,376 Views)
I ended up having to delete the event and recreate it to get it to update. I hadnt thought about that.
(3,373 Views)
