remove items from 1-d array
I get 'target' as the deleted portion fine. It's just that instead of it being deleted from the array I get an array where it is replaced by a second copy of the smallest member of 'used odors'.
Message 11 of 23
(2,269 Views)
The 'target' value must be identical to a value in the "used odors" array to be found by the "search 1D array" VI
Message 12 of 23
(2,268 Views)
@NeilR wrote:
They will be if the 'target' value cannot be found in the "used odors" array.
In that case an invalid value of -1 will be passed to "delete from array" Smiley Wink
Interesting.  I didn't expect a -1 to not "delete from array".  It actually didn't put a smallest value in.  It put a zero at the front.  And the array isn't the same size, it is one element longer.
Message 13 of 23
(2,262 Views)
I just have an array of numbers for "used odors" > 3,4,5,6,7 and enter 77 as the target.
The "array w/ subset deleted" becomes 3,4,5,6,7 no deletion ... but no addition either ?
Message 14 of 23
(2,254 Views)
If I understand what you want, you just want an array with the number equal to "target" removed? Am I correct in this understanding? If so, here are two ways to do it. I don't know if autoindexing does inplaceness in 2013, never bothered to benchmark again, but I think it was supposed to be optimized.
Message 15 of 23
(2,252 Views)
Simpler, put the Delete from Array in a case structure with the DFA in the true case.  In the false, just wire the array through.  Use a >=0 on the index from search from array to control the case structure.
And if your values are integers, stop using a double data type!
I still don't see how you get the results you say you are seeing.
ATTACH YOUR VI WITH DATA!
Message 16 of 23
(2,243 Views)
Indeed.  Bizarre !
Message 17 of 23
(2,238 Views)
I think this has the data.
Anyhow, odors used = [3 5 9 14 1].
Target = 5.
the array with deleted element  is [1 3 9 14 1]
Message 18 of 23
(2,237 Views)
Accepted by DRLV
Your Index on the "used odor" control is set to 1 rather than 0 !!!!!!!!!!
This hides another value Smiley Very Happy
Message 19 of 23
(2,227 Views)
Check your control.  It is [1 3 5 9 14 1].  You just have the index set to show element 1 instead of element 0,
It works just fine.  (But still make it integers instead of doubles.)
Message 20 of 23
(2,225 Views)
