05-01-2014 07:29 AM
I am working on data acquisition using labview and cdaq 9191 chassis + 9234 module by using DAQ Assistant.
The DAQ Assistant captures data from the chassis, feeds it into a shared variable and then the VI deploys it over a network.
This worked perfectly about 4 months ago. After That I uninstalled LabView and other drivers.
After reinstalling the whole setup again now when I create a new project and try to put DAQ assistant in the VI, it gives an error - "the remote target is missing required components".
What might have caused this problem?
05-01-2014 09:40 AM
Hey Egupta,
What versions of LabVIEW and the DAQmx driver are you using? You can check this by going into Measurement & Automation Explorer and expanding out the Software tab.
Are you sure that you installed the DAQmx driver after you installed LabVIEW? It might be worth reparing the driver if you are unsure and we determine that they are compatible versions.
KiraT
05-01-2014 12:17 PM
I am attaching the screenshot of the expanded Software tab.
05-01-2014 01:15 PM
Those should be compatible. Have you tried a repair on DAQmx?
When you used this previously were you on Windows 8? According to this document Windows 8 is not supported for the version of LabVIEW or DAQmx that you are running. It doesnt mean that it definately will not work, but it could cause some problems.
On a different note, are you able to see the 9191 in MAX?
05-02-2014 12:10 AM - edited 05-02-2014 12:20 AM
Yes, I used it previously on Windows 8. Also, I am able to see 9191 in MAX.
I have observed one more strange behaviour: when I put DAQ assistant in a blank VI, it works fine. But when I create a new VI in a blank project, it displays the error message.
Could you please tell me which driver version is compatible with Windows 8 or rather give me the link of the related document?
08-06-2015 10:17 PM
Anyone solve this error? i also having the same problem
