remote desk connection
The test station where I am developing my code has two monitors, very useful for developing LabVIEW.  Sometimes I log in remotely from home but then I can only see one monitor view.  Sometimes I accidentally leave VIs, or worse, the tool box, open on the second monitor and then it is impossible to access them from home, very annoying.  Is there any way to force LabVIEW to move these forms to my main screen from home?
Message 1 of 13
(4,632 Views)
Ugh, I haven't figured that one out, either.  I hope someone has a solution!
Bill
CLD
(Mid-Level minion.)
Message 2 of 13
(4,613 Views)
SIGH! At least I know that I am not the only one!
Message 3 of 13
(4,590 Views)
Can you access the Windows TaskBar and Cascade Windows? This should pull all windows to the primary display.
Message 4 of 13
(4,570 Views)
I can recommend a program called 'DisplayFusion' - it's a multi-monitor taskbar for Win 7/8 etc. that gives you a full taskbar on both monitors, allows you have windows appear on the appropriate taskbar, have different wallpapers for each monitor etc. etc.
It's a very handy program if you have multiple monitors and well worth the license cost (I use it at home and at work and couldn't do without it on multi-monitor setups).
Particularly for your specific problem - It's very configurable and allows you to create a whole load of keyboard shortcuts for things like:
- Move all windows to current monitor
- Move window to current monitor
- Move to next/primary/previous monitor
etc.
(blog)
Message 5 of 13
(4,552 Views)
Or right-click the window in the task bar and select "Move", then use the arrow keys to move the window.
Message 6 of 13
(4,550 Views)
This does not work for any of the palettes.
Bill
CLD
(Mid-Level minion.)
Message 7 of 13
(4,543 Views)
I like the move and cascade options, but, as you say, none of the above works for the tool box.
Message 8 of 13
(4,525 Views)
You can always open a "temporary" tools palette by shift-right-clicking the diagram. Of course not an ideal solution if you need it frequently.
Message 9 of 13
(4,518 Views)
I've found some times a window can be selected, which is on a monitor that doesn't exist, and by pressing Windows+Shift+Right it will move the window to the next monitor, because that monitor doesn't exist it will move it to my main monitor.
Another option might be to write a tool that resaves all VIs on the main monitor, but honestly this should be considered a bug and fixed.
Message 10 of 13
(4,488 Views)
