relay program problem
When you double click any of these DAQ Assistant, you'll see the configuration window (like one I attached below)...!!
I'm more interested in inspecting that...!!
Also I'm not understanding, why're you not sharing the code...!!
That will be easiest to see, understand the issue and explain a solution to you...!!
Again..by saying code, I dont mean your Credit card CVV code or something like that... I mean to say LabVIEW VI.. (the physical file saved on hard disk)...!!
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 11 of 15
(973 Views)
i  don't have the code on hand.....i left it at school computer
Message 12 of 15
(970 Views)
Ohhh...
Anyways...!!
You can try following code..!!
Message 13 of 15
(962 Views)
where can i find this??
Message 14 of 15
(952 Views)
I have a quick question for you, since how many hours have you been using LabVIEW...???
And after this current project of yours will be over, are you really continue gonna use LabVIEW....???
Now regarding:
You can find this (a boolean indication) on the controls palette.
Message 15 of 15
(937 Views)
