reinitialize cursor
Hello, I have a graph with 3 cursosrs. I initialize their position at point 0,0 using Property Node, Cursor, Position X at the beginning of my program. When I run the program all it's ok the first time, but when I run it again without close it, the cursors aren't initializated. What can I do?
Thank you very much.
Luz
Message 1 of 10
(7,129 Views)
Are you setting the Active Cursor property before setting Cursor X?
You should do the following in a single property node:
Active Cursor=0
Cursor X=0 (or whatever you need to reset)
Active Cursor=1
Cursor X=0
Active Cursor=2
Cursor X=0
You may also try to set the Cursor Index in the same way.
Paolo
Paolo
Message 2 of 10
(7,122 Views)
I did it, but I haven't result, what can I do Paolo?
Luz
Message 3 of 10
(7,117 Views)
Difficult to say.
To get more help, please post your vi or an excerpt exhibiting the problem.
Paolo
Paolo
Message 4 of 10
(7,112 Views)
hi luz,
ar u using lv 8???? or u ar using 7.1?
I send you an example in LV 7.1 and another in LV 8.0
As you will see in 7.1 everything goes perfect.
In LV 8.0 there is a bug because the cursos go to position (0,0) and also that is on the position property node but in the legend you still see the old value.
If that is a very important issue for you and you want to correct it, this is solved in LV 8.0.1 so you can update your LV 8 version downloading the 8.0.1
If you do that please read carefully the next knowledgbase:
http://digital.ni.com/public.nsf/websearch/D5C32AD00F07D7D586257110007B54D2?OpenDocument
There are some important issues at this document you should take in consideration about the installation of LV 8.0.1
Jaime Cabrera
NI Applications Engineering
Jaime Cabrera
NI Applications Engineering Spain
Message 5 of 10
(7,093 Views)
Hi Luz,
Another solution,
This link talks about the think is happening to you and gives a solution,
[link removed]
Just do it twice.
Jaime Cabrera
Jaime Cabrera
Message 6 of 10
(7,092 Views)
OK that's a bug.
What is the CAR#?
Ben
Message 7 of 10
(7,084 Views)
CAR 3QDAII5C
Fixed in LV 8.0.1
Jaime Cabrera
Jaime Cabrera
Message 8 of 10
(7,082 Views)
Thank you!
Ben
Message 9 of 10
(7,080 Views)
As Jaime mentioned...
This was reported to R&D (# 3QDAII5C) and was fixed in LabVIEW 8.0.1.
Thanks!
Travis H.
LabVIEW R&D
Message 10 of 10
(6,811 Views)
