regular expression or format into string (nevermind)
Solved it,
I can use string to fractional number!
I have a 2D string array from a multicolumn list box, and i want to check if every value is valid number, the numbers can be a single and can have negative values. Does anyone knows which regular expression i need to check this, or is there an ever better way doing it?
Thijs
(3,086 Views)
Accepted by topic author ThijsBoeree
solved!
(3,082 Views)
You shoudl post your solution so others who have a similar issue can learn from how you solved it.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,062 Views)
Hi
I know, but this was to simple, i wanteded a zero if a character was filled in the multicolumn listbox, and when using string to fractional number it does!
Best
Thijs
(3,043 Views)
