regular expression help
I have a string I want to employ a regular expression on to avoid a cascade of match patterns, but I can't seem to get it to work.
The string:
^XA~TA000~JSN^LT0^MMT^MNW^MTT^PON^PMN^LH20,0^JMA^PR4,4^MD0^JUS^LRN^CI0^XZ
^XA^LL0076
^PW376
^BY25,25^FT25,38^BXN,2,200,0,0,1
^FH\^FDP1000^FS
^FT0,56^A0N,20,20^FH\^FDP1000^FS
^FT180,65^A0N,42,40^FH\^FD^FS
^BY25,25^FT150,38^BXN,2,200,0,0,1
^FH\^FDP1001^FS
^FT120,56^A0N,20,20^FH\^FDP1001^FS
^PQ1,0,1,Y^XZ
What I want out of it is one instance of:
P1000
P1001
In this example. The number portion will be different for other strings, such as P4567, PA34554, etc. It will never vary from P or PA. The number section might be 4 or 5 digits long.
Each of these show up twice in the string.
The regex I was trying to use is:
\^FD*\^FS
and then I was going to weed out the duplicates.
And now my brain gives up.Smiley Sad
Tay
Message 1 of 8
(5,715 Views)
The characters "\" and "^" have special meanings in regular expressions.  Why don't you just search for P and PA, followed by numerical characters?
- tbob
Inventor of the WORM Global
Message 2 of 8
(5,703 Views)
Accepted by slipstick
This vi extracts all P followed by numerical characters.  You have to modify it to include PA.
17993iE5847D04BBA462D2
- tbob
Message 3 of 8
(5,700 Views)
Thanks. I wasn't able to get the P or PA search to work either. I don't use regex functions enough to be really familiar with them.
Tay
Message 4 of 8
(5,695 Views)
Or this...
18031i00A8E35BC5E510CD
I learned a lot from this site.
Jim
Message 5 of 8
(5,668 Views)
I need to learn regular expression.  That site has a lot of info.  Thanks Jim.
- tbob
Message 6 of 8
(5,645 Views)
Excellent site! And thanks for the code!
Tay
Message 7 of 8
(5,638 Views)
I was on travel so I couldn't reply earlier, but I was glad to see Jim defend the honor of the regex.  Call me old-fashioned, but I do not have OpenG installed on all of the machines I come across.  Instead of deleting the duplicates, what I do instead is to use the attribute of a dummy variant to hold the values.  Duplicates are nicely handled and the final iteration errors out when you try to write an empty name.  I do not use it here, but I made the number itself a capture group, so the value of each attribute is the number itself.
18075iCAB38B4EC0C68457
Message 8 of 8
(5,611 Views)
