regular expression alarm url
I have a problem with regular expression. I would like to filter only the name of a dsc alarm url: \\EW-MONITOR\monitor\000_t-ist_STB-M1-AS.Alarms.HI should be 000_t-ist_STB-M1-AS . Has somebody an hint for me?
Best Regards,
Joachim
(3,442 Views)
Best Regards,
Joachim
What will be constant in the name?  Will it always be between "monitor/" and ".Alarms"?  Will the format always be "###_<some text>_<other text>"?
This will be easy once I know what to look for.
Jim
(3,427 Views)
Accepted by Joachim082
If as jcarmody asked, the name will always be between "monitor\" and ".Alarms" use the sub match output of Match Regular Expression
It pulls out the alam name from the whole match.
Omar
(3,416 Views)
And, if the other option is true, this regexp will give you the name in the "whole match" output.
Jim
(3,405 Views)
Thanks, that works great for me
(3,395 Views)
Which one?
Jim
(3,393 Views)
