reading values from lcd using vision
ma project is to read values from a lcd display...i was not able to set an roi ... cn any help me out...i hav attached my codes
Message 1 of 11
(5,222 Views)
Please stick to a single thread, don't create duplicate threads. Also don't use short forms its not encouraged.
Since I don't have Vision module let me ask you what you have done. Are you trying to capture the LCD as an Image? What is the hardware you used?
Message 2 of 11
(5,189 Views)
Is the point of the application to read whatever appears on the LCD, or just determine whether the LCD is working?
These situations could require 2 very different answers.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 11
(5,169 Views)
to read the values whatever in lcd
Message 4 of 11
(5,138 Views)
What kind of LCD is it, and why can't you set an ROI?
Mike...
LabVIEW Champion
Message 5 of 11
(5,124 Views)
It is a 7 segment lcd display.......i used get lcd roi...in that i am getting invalid roi......i dont know how to set an roi
Message 6 of 11
(5,115 Views)
If you have vision assistant you can try image mask. Post an image if possible. What is the camera that you are using?
Message 7 of 11
(5,106 Views)
i am using a web camera......i want to set roi for lcd....i m using get lcd roi dispcriptor nd read lcd functions in my programe.......i dont knw how to set roi in lcd roi discriptor.....
Message 8 of 11
(5,101 Views)
Did you try the image mask function?
Message 9 of 11
(5,089 Views)
i have tried selecting area using rectangle and i converted it into roi discriptor,,,but the roi discriptor which is given to get lcd roi discriptor......has a result that invalid roi discriptor....
Message 10 of 11
(5,057 Views)
