reading usb data
I am using a labview application (don't know which version, as it is third party application). The peripheral is a sensor which sends data out using DB15, SPI. The data then goes through a converter box, and comes out as USB which connects to the PC. The application has a "start measurement" button which starts reading from the peripheral. I wish to replicate this in a custom application of mine to be built in labview 2012. How should I go about doing this?
Peripheral board is : http://www.acam.de/products/picocap/pcap01/evaluation/   see PCAp01 eval kit. screen shots of software are provided in link.
Thanks in advance
Mukund
(2,267 Views)
1. The link is broken.
2. Source code should be prvided.
3. You should give an information how do you want to customize it.
(2,254 Views)
