reading from serial port
Thanks. I am sure that it wasn't used with another program.
What my guess is that because this device that I connected to the port #x has a problem of sending! may be this is the issue. I can investigate it better till Tuesday with my new device!
Sb
Message 21 of 36
(2,680 Views)
The device you have connected is irrelevant. VISA does not know or care what you have connected. You could get that error with nothing connected to the com port. The error is referring to the com port itself. Windosw does not allow more than one process to access a com port at a time.
Message 22 of 36
(2,666 Views)
Then it is too bad. YOu mean evern without labview, I still have this problem?
Is there any way? to read from two port?
Thanks;
Sb
Message 23 of 36
(2,656 Views)
There is no problem with reading from two ports. It is done all of the time. The last time I did it was last Thursday. You have a local problem that you need to resolve. Something, whether it's MAX, a modem program, whatever, is also using one of the ports.
Message 24 of 36
(2,652 Views)
I see. Now make sense. As long as I make sure the LabView program is working correctly, and no problem with configurations, then I can take care of other problem.
Sb
Message 25 of 36
(2,646 Views)
Sb
Actually, just the opposite.  You need to take care of the other problem before you can know for sure your LabVIEW program is working correctly.
Message 26 of 36
(2,627 Views)
I tested two ports seperatly and symelteniosly with two different programs. I run one port with Hyperterminal, and another port with BrayTerminal. I received data. So there is no problem with Windows.
The problem wih LabView it may my devie. As I mentioed one of the port gave me wrong value because of the funcionality of my device. I can be sure by Tuesday.
I appreciae all of your helps.
By the way, can I ask  a question about the string?
Cheers;
Sb
Message 27 of 36
(2,614 Views)
I already told you the error has nothing to do with the device. Of course, closing those programs may cause the error to go away and then you'll think that swapping the device fixed it. Simply not true.
Message 28 of 36
(2,602 Views)
Cheers;
Sb
Try the same thing in MAX, then you can see how it works in LV environment.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 29 of 36
(2,590 Views)
I am not familiar wih LV environment. What is that? I couldn't find it online. IF you could please give me a link.
Thanks a lot;
Sb
Message 30 of 36
(2,570 Views)
