11-01-2010 02:56 PM
LV = LabVIEW
environment = doing it from within LabVIEW as opposed to somewhere else (e.g. MAX, LabWindows, ....)
11-01-2010 03:57 PM
@Ravens Fan wrote:
LV = LabVIEW
I'm probably wrong, but i count MAX to LV environment as it's a requirement to use the ports in LV, just more on the ... driver level. 🙂
/Y
11-21-2010 09:27 PM
HI again;
I could be able to run two ports simultaneously and I received data from both ports!
even if any program is not running in labview, or I just click to run the program my computer re-started automatically, This happened several times! I scanned the computer there is no any virus, and also if this specific Labview program hasn't been running, this auto restarting never happened!,
I am sure this crash is because of labview program.
Do you have any idea?
P.S. I am connecting two Bluetooths (with com port) to communicate with Laview program,every time I want to run the program I should restart Labview to recognize the ports.
Cheers;
11-21-2010 09:40 PM
Does it show any error messages before restarting? Is it blue screening?
11-21-2010 11:08 PM
No at all, nothing. It is the same as some one press the restart button!
I checked with other Labview program, I didn't see any wrong. Just crach in this specific one.
11-22-2010 11:39 AM
By the way, this happened just with Bluetooth mates. By using wire to pc, it works fine!
