reading data into labview from accdb file
Hi there.
All I want to do is read the data in a .accdb (MS acess 2007 and later) file and be able to use that data in labview. It is just a table with a bunch of numbers. I know how to do with excel but i am getting confused with MS acess. I am try to play around with LabSQL right now but still getting confused.
Please help!
thanks.
Don't think twice.
(3,722 Views)
Accepted by topic author sb_oxinst
What are you specifically confused about? Before using LabSQL, I would suggest you find a good tutorial on the SQL language. NI's Database Toolkit can also be used. It hides some of the SQL complexity for the beginner.
(3,717 Views)
yes of course. I use one of the examples in LabSQL and then looked at SQL code to help me retrieve data from a column and it worked. I think I just got l lost in all my research and not knowing what SQL really is. I had also downloaded sql_LV-1.09 which is another labview database library for ODBC and SQL but I was getting an error saying it could not locate the libmysql dll file.
thanks 🙂
Don't think twice.
(3,714 Views)
