read tinytalk logger with labview
hi,
has anyone ever tried to read a gemini tinytalk datalogger with labview?
Or does someone have information about the protokoll (RS232 1200bd? 7n2??)
Greetings from Germany
Henrik
LV since v3.1
(3,172 Views)
I wonder what you intend to use Labview for as the logger is a standalone device.
I could not locate a protocol document.
Anyway you can work back through the protocol information by looking at the example code on the Gemini web site.
http://www.geminidataloggers.com/
You need to follow the link to developer information
http://www.geminidataloggers.com/developer
There does not appear to be specific Labview support although I looked through the code and it looks reasonably straight forward to port, if a little tedious.
(3,153 Views)
You are right, it's a standalone application. However sometimes I need to merge the tinytalk data with data from my Labview application(s). Since it's (simple) RS232 I like the idea to do everything in G. I don't really like to analyse line code 🙂 and haven't found a protokoll description.
Looks like I need to request a licence and start to learn Python 😕
Henrik
LV since v3.1
(3,145 Views)
Perhaps what you should do in the first instance is export the tinytalk data to a text file using the support application.
Then merge the data in Lbaview.
(3,135 Views)
Did you ever progress this project into LabVIEW code?
If you did would you consider sharing it?
I was just reading through old posts and this was one that caugt my eye again.
Regards
(3,062 Views)
