read strings from array for loop
Hi Everyone,
I have a problem here,
I have not found a way for my FOR loop to read the strings from my array. My FOR loop currently can only read the first element in my array. Do anyone know the way for my FOR loop to read all my elements?
Alan
Message 1 of 12
(5,179 Views)
index enabled the tunnel?
Message 2 of 12
(5,176 Views)
I tried that before but thanks anyway, my loop is inside a case.  It does not allow me to Index Enable the loop.
Message 3 of 12
(5,159 Views)
please post your VI
Message 4 of 12
(5,155 Views)
I can't give you all of my .vi but I'll show one of them I made.
Message 5 of 12
(5,149 Views)
you dont have an array entering your FOR loop?
Message 6 of 12
(5,143 Views)
Hope this will answer.
Let me know.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 7 of 12
(5,134 Views)
Nope I'm doing a simplified parser for XML. My program is a little more complicated.I have to read many different values from a single source of string using match pattern. Then I need to loop my program the same number of times a value is shown on the string, but everytime I input my array of string to my vi.... Only the first value the match pattern could detect and not the rest of the data, This VI is just an example, I need to make a program suitable for many boolean in this case. I was wondering if there are other ways better than using for loop or for loop with shift register. Thanks!
Message 8 of 12
(5,114 Views)
What is many different values from a single source of string?
Give one sample source string and what output(s) you are looking from that.
--Ranjeet
Message 9 of 12
(5,108 Views)
Hi Ranjeet,
It's in my attachment eee.jpg where the G!@#$%ibberish XML is the source of string and I will need all the values in the '<val>'s... and </val>'s... But now my program could only get me one of the values.
Alan
Message 10 of 12
(5,101 Views)
