Error 1 occured at get queue status
Hi all,
I am getting the error message "Error 1 occured at get queue status" in my LabVIEW program where it is dequeuing. I have attached screen shots of the error, the place where it is occring in the program and the VI.
1) The error occurs in the wire 107 as could be seen from the attached picture. I will be really happy if I get help to resolve this error.
2) This program write only the starting time stamp but I want to have a time stamp of all the data being written. Can someone help me do it.
Many thanks,
Ramji
(7,147 Views)
Error 1 is an invalid input.  For a dequeue as you have shown, you probably have an invalid queue reference.  You will need to trace back to find where it goes bad.  Check the error output of the previous queue operation.  It is probably also bad.  If you created your queue reference elsewhere, it may be cleaned up before you use it, resulting in the error.  You may not have connected it somewhere (using required inputs on VIs helps this).  There are lots of reasons this may be happening.
Note, you can check whether a queue reference is good by creating a custom probe and checking the queue status in it.  Do not dequeue anything in the problem.
(7,105 Views)
Your problem is likely that your Producer loop is completing before your Consumer loop.  That in itself is fine except for the fact that you are killing your queue as soon as the producer loop is complete.
First of all, you don't need the Queue Status at all.  Just use the Dequeue Element.  It will sit there and wait for data to come in.
Secondly, if you want to process ALL of your data, you need to use the queue to tell the consumer loop when to exit.  In your instance, I like to send an empty array.  Then after the consumer loop is complete, kill the queue.
Attached is a modified version of your VI.  It is far from complete, but it will hopefully show you what I mean.
(7,098 Views)
Just one more thing.
There is a data dependency between the two loops.
The timestamp (Time stamp 5) is going out of the producer and into the consumer.
The consumer will never start before the producer is finished.
(7,096 Views)
Nice catch.  I can't believe I missed that.  I guess I was too focused on the queue.
So what you really want to do here is have the queue accept a cluster.  The cluster should contain your 2D data and the timestamp.  Then you don't have to pass the timestamp via a wire between the two loops and you will have the correct time stamp for your write.
Another thing I noticed, you do not need the To/From Dynamic Data nodes in your producer loop.  The graph will accept the 2D array just fine.
(7,094 Views)
I have read all your suggestions/corrections. I will edit my program after 6 hours from now and keep you all updated.
Thank you so much for taking time to looking into it.
Many thanks,
Ramji
(7,076 Views)
