‎02-07-2018 05:46 AM
I need connect My biometric sensor with labview .can i use VISA for that one.otherwise is there is any other method for integration.
Solved! Go to Solution.
‎02-07-2018 08:32 AM - edited ‎02-07-2018 08:37 AM
perhaps
edit: https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495
‎02-07-2018 10:09 AM
What sensor are you using? What interfaces does it have for getting the signal?
‎03-10-2018 09:05 AM
Did you get your code/info related to Fingerprint sensor & How to use it with LabVIEW?
‎03-17-2018 03:02 AM
Can u help me to get the fingerprint data or send any example code
‎03-17-2018 04:36 AM
I'm using R305 fingerprint sensor.
It has UART pins and we used UART to USB connect & connected it to my laptop with LabVIEW 2015, VISA and VISION drivers.
I had gone through the documentation, it described as Serial Communication
I dont know how to start that with VISA functions!
