Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
DAQmx simulated device - DAQmx Create Scale (Linear).vi
I know when we use simulated DAQmx hardware, we have to face certain limitations. May I get info regarding to the "DAQmx Create Scale (Linear).vi"? I would like to test my application, but I do not have the hardware yet. So I just use a simulated device. Whatever value I set for the "slope" input, the simulated measurement does give the same values.
My guess: the Scale VI does not have any effect on simulated DAQmx devices.
Is there a exhaustive feature list for simulated DAQmx devices? Like what they support, what they not?
Thanks! 🙂
Edit: Shame on you Blokk! 😄 I just googled for it: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Nw0SAE
I guess this is the explanation: "When reading data, all analog signals will be returned as a full-scale sine wave with three percent of full-scale noise. Digital data is returned as if each 8-bit port were counting up. "
Message 1 of 1
(2,587 Views)
