read file metadata
Is there a way to read file metadata in LabVIEW?  If I was looking at an executable and wanted to retrieve the version number (that shows up when you look at the file's properties in windows), how would I do it in LabVIEW?
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
(6,877 Views)
Here ya go,
This should do the trick for you.
Message Edited by Chris_VH on 03-30-2009 05:36 PM
Chris Van Horn
(6,876 Views)
Thanks.  I should have clarified this earlier but I'm not asking about an executable or a VI that is built using LabVIEW.  What if I was looking at an exe or a dll built using something else.
S G
(6,870 Views)
I would think this could be done with an ActiveX control.  I browsed MSDN but couldnt really find anything.  I'll look around some more, but I am sure something is out there.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(6,831 Views)
Read file metadata
(4,362 Views)
