02-05-2007 04:36 PM
02-05-2007 04:48 PM
02-05-2007 04:53 PM
What do you mean by 'assistant'? The only assistant that would seem to apply would be the Instrument I/O Assistant but you would only use that if you didn't have a driver. I don't have the instrument and didn't go to Yokagawa's site but there is a driver on NI's site at http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E9103659CE034080020E748.... Open the YKWT1X0 Getting Started and try that.
With GPIB instruments, the error you are getting is often because you are doing a read and the instrument has no data to return. That could be because of various reasons, including not sending the correct command to the instrument that instructs it to take a measurement.
02-05-2007 05:37 PM
that's the same driver I already have. So I don't need to use the assistant. Thanks, I'm quite newb at this.
*runs away to figure out how to get the data to show up*
