read delimited spreadsheet with ~10e6 rows
@Ben - would you mind sharing the code or toy code for some of that?
Message 21 of 24
(967 Views)
I would love to but my hands are tied.
Spoiler
or would be tied and locked up if I shared it outside of the barbed wire fences (smiley-wink)
But I can outline the process to modify the Read From Spreadsheet.
Open the read from spreadsheet VI and do a "save As..." so that you will have a copy outside of VI.lib
Change the input to a I64
Find the sub-VIs inside your new Read From Spreadsheet
Do a "Save as" on them and update the caller.
Lather rinse repeat all of the way down.
Be careful not to have the VIs from VI.lib open when you proceed. You do not want to foul your stuff in VI.lib
Use the "VI Hierarchy" screen with option to "view full path in file label" to make sure you are working with your version and not screwing up vi.lib.
If you are uncomfortable with the above, back-up the stuff in VI.lib before you start.
Have fun and be patient!
Ben
Message 22 of 24
(961 Views)
@Ben - I just say "I have a non-disclosure agreement, and violation would be 'career-limiting'".  I understand.
I was more interested in the producer-consumer for reading/transforming a stack of files asynchronously.
Message 23 of 24
(952 Views)
On that note...
Normal producer/consumer but use fixed size queues between them. If the processing loops backup, the producer loops will stall waiting for room in the queues.
Beyond that, I would have to look at the code and not just that fuzzy image in my heads. Smiley Tongue
Ben
Message 24 of 24
(941 Views)
