read array size and based on Array Size read rows (columns) one by one
.... I wuld like to gett Values out of a loop after each iteration.... is it possible?
Message 11 of 15
(725 Views)
I don't understand what you're asking here.
Looking at your code I can't help but feeling as if you're only telling us part of the story. I mean, with all of that code, you must be trying to do something really big, right? After all, translating the text file to a table as has been mentioned isn't all that hard, and does not require all of that code. I saw stuff in there trying to deal with leap years, and which day was the end of the month, depending on what month it was. There's also a global variable (not included in upload) whose purpose escapes me. You also seem to be adding a value to the values.
So... what's the whole story?
Message 12 of 15
(708 Views)
i just need the Values for each iteration  to be writen out of the loop  in Real Time....:(
Message 13 of 15
(706 Views)
i shoulld "push" them out of this VI (for every iteration) Numerc as Numeric, String as String, Value as Value.....
Message 14 of 15
(705 Views)
Push them out to where? You already have them on a front panel. As I said, I don't think we're getting the whole story here, as you only seem to be providing bits and pieces. I would still like to know why you're doing what you're doing with all that code.
Message 15 of 15
(696 Views)
