read and save settings from instruments
Currently, the 'save config' case saves the data read from the user interface (in the 'aggressor settings' tab)
how can I change this 'save config' event so that;
- Read all the insturment settings from hp8133s and hp8648 (along with GPIB addrs)
- Load into the user interface
- Save to a file (*.ini)
Message 1 of 38
(5,661 Views)
In order to determine how an instrument is actually set up if done manually, you will have to write the queries yourself as these are not normally part of a driver. With SCPI, the query is usually the command used to set it with a question mark at the end. For example, if the command to set a DMM's function was FUNCTION:VOLTS DC, in order to read what it is, you would issue the command FUNCTION? and then do a read and get the value VOLTS DC. You will have to read the individual programming manuals to determine the actual command syntax for the instrument and decide which parameters you wish to read and save. Once you've done that, you can write that information to your existing clusters that will update the front panel controls, run the "set config" case and the "save config" case.
Message 2 of 38
(5,642 Views)
I did find SCPI commands from the user manual of hp8133, but I am not sure how I should get started. I wonder if there is any example that I can take a look?
Message 3 of 38
(5,623 Views)
Hi jjllee,
One of the vi's in the driver library is "initialize".  In that vi they use the command *IDN? to query the ID of the instrument. That is an example of what Dennis is talking about. Now you just need to develop similar vi's for the queries you are interested in.
cheers,
--Russ
Message 4 of 38
(5,617 Views)
Hi Russ,
Thanks for your suggestion.
I looked at the user manual with SCPI section and they all seem like set & query is the form for all these commands. I though I only need to open VISA session and read in function with appropriate 'string' command from the manual. However, all the examples are for setting a particular parameter. (e.g., setting duty cycle on page 5-35)
plz see the attachments....
Message 5 of 38
(5,586 Views)
here is the manual
Message 6 of 38
(5,584 Views)
jjlee,
I think if you look at page 5-3 you will notice that nearly all if not all commands have [?] option. So if you want to read what the duty cycle is you simply write your string as if you were going to set the value but instead of a value you use a question mark.
for example to query duty cycle chan 1 would have a string like the following
": PULS: DCYC1?"
Also the 8133 is in the NI instrument driver network have you download their libraries and examples at
http://www.ni.com/devzone/idnet/default.htm
hope this helps
Cheers,
--Russ
Message Edited by Russ Evans on 05-24-2006 05:49 PM
Message Edited by Russ Evans on 05-24-2006 05:50 PM
Message 7 of 38
(5,583 Views)
Hi jjlee,
with regard to 8648 generator instead of saving all of the setup values,
 why don't you just do a reset command ? Which will place the instrument in the factory default state.
 Thus all you need to do now is write ( already saved values) the parameters that you wish to start up the statea in.
If you read the manual I'm sure that it explains what the factory initial state parameters are.Also you know that you are in a predetermined  condition.Remember
to query the state after you have written the command!!
 Else you could end up frying your electronic circuit if you assume that the instrument has understood the command that you wrote to it.
As a rule of thumb:
 if changing several parameters it is prudent to disable the output before doing the ammendements.
xseadog
Message 8 of 38
(5,569 Views)
Thank you all for your helpful suggestions!
Message 9 of 38
(5,488 Views)
I have created this case, "load instrument settings"
First four settings are from hp8133A voltage output.vi (from instrument library)
and the last two pulse setting VIs were modified version from voltage output.vi
I have created an array to gather all output values, but don't know how to pass it on to the front panel...
could you please advise on how to accomplish this?
Message 10 of 38
(5,461 Views)
