read a bmp file from computer
hi ,
I have tried to read a picture of .bmp format from my computer to the front panel. But it is showing an error.
I have attached the error message and the way I have done to copy the picture.
Thanks in AdvanceSmiley Wink
@nk
Message 1 of 10
(5,072 Views)
Can you rename the bmp file with a simple name and try to read again?
Message 2 of 10
(5,056 Views)
No the same error is coming.
@nk
Message 3 of 10
(5,048 Views)
One more try, please relocate your bmp file to may be c drive and test. Also please attach your code
Message 4 of 10
(5,043 Views)
Still the same error is coming
@nk
Message 5 of 10
(5,038 Views)
The VI works just fine. Can you try with a different image?
Message 6 of 10
(5,034 Views)
In my computer still the error is coming
@nk
Message 7 of 10
(5,028 Views)
Accepted by @nk
Can you Navigate down to the Read BMP File data.vi and check where the error occurs? Are you using this vi along with any othe piece of code which may be giving error to the input of this vi?
Save the bmp file once again from paint as bitmap file and check.
Message 8 of 10
(5,018 Views)
Now it is working , so what could be the problem? i just saved it in paint that's all. now can i do it using labview because in my code the user selects the image which is a snapshot from a camera, so i dont want user to open again and save it in paint . what could be the reason behind the error.
@nk
Message 9 of 10
(5,010 Views)
The file format might be different and you could have just renamed to .bmp. Check the file format of the snap shot and use the same file format function to save the image.
Message 10 of 10
(4,990 Views)
