"unspecified hardware failure" on a PXIe-7966R FPGA, how to tell if a card is bad, what are my next steps?
Greetings,
I have a PXIe-7966R that shows up in NI-MAX and I add it to a project. However, when I try to run code on it I get the following
"Error -63150 occurred at niLvFpga_Open_PXIe-7966R.vi:6270001; An unspecified hardware failure has occurred. The operation could not be completed."
I am trying to run a very simple code on the device (see attached) just to make sure the card works. However, it is not. What would my next step be here? Should I try to update the firmware? Is it just "bad"?
Also, I have a PXI-7951 in the same system and I can run the code just fine so I don't think its a code issue but rather a hardware issue.
Thanks!
Message 1 of 1
(1,490 Views)
