"relative" real time
Do you have some real data for use to see what your data looks like? That would help tune the back end of the program.
Tim
GHSP
Message 11 of 32
(1,267 Views)
How many RPS do you expect for this system?
Tim
GHSP
Message 12 of 32
(1,263 Views)
Are you only getting one Pulse for an RPM? How are you generating pulses for the RPM measurement? Sounds like a quadrature input to a high speed counter would be better. It also seems to me that you are going to want this loop measuring constantly.
Tim
GHSP
Message 13 of 32
(1,261 Views)
I think this should get you closer
Tim
GHSP
Message 14 of 32
(1,258 Views)
I agree with Tim,
Some other sensor would be better.
Message 15 of 32
(1,248 Views)
Hi NI was down for me so i couldn't log in to see replies.
Thanks for the help first of all.
Here is my VI with a signal generation subsitute for my DAQ.  i know this is not an optimum setup and that a digital counter would be much better - but an anlog tachometer is what i have right now.
Attached is my VI.  In the bottom right of my VI there is a for loop which i started.  I found the sample/sec rate...and what I wanted to do was multiply it by the number of samples to get the time....but its not workign because I think the for loop runs too fast for what i want to do.
Like i said, ultimately, I want to show that between two 5 volt peaks is one revolution, and i would like to see how that angle changes with time.
Attached is the VI.
Message 16 of 32
(1,224 Views)
The system is running at about 8.3 hz (500 RPM) but can run up to 1000 RPM or as low as 200 RPM
Message 17 of 32
(1,222 Views)
Did you look at my code? I added your simulated code and it seems to give the correct answer.
Tim
GHSP
Message 18 of 32
(1,182 Views)
I would also suggest that you move to continuous data acquisition. This would remove the time part that you are missing. The way I did it using your original code will work but there will be timing errors. A high speed encoder to a high speed counter that has quadrature input would be the best way to measure this. Especially if you are looking to do some sort of angle measurement.
Tim
GHSP
Message 19 of 32
(1,179 Views)
OK I looked at your example a little closer. I think it will be easier than what you are making it. If I understand what you are doing you will get one pule everytime the sensor make one revolution. If I am getting 500 pulses in one minute thqan we are getting 500 RPM.
This new code should do what you want to do if everything that I assume is correct.
Tim
GHSP
Message 20 of 32
(1,169 Views)
