‎02-03-2009 10:29 AM
‎02-03-2009 11:08 AM
I have a dual core Laptop and I created two while loops both reading data out of the same cluser. I opened task manager to the perforamnce tab where I have it set up to show one graph per CPU. I got 100% on both graphs! Try a simple program with four loops all readying off the same global. Make sure the loops have no delays (very bad programming practise) just for this experiment.
Amit
‎02-03-2009
01:14 PM
- last edited on
‎04-27-2025
08:40 PM
by
Content Cleaner
LabVIEW will automatically make use of multiple cores/CPUs. If you want more precise control you can use a Timed Loop, as those allow you to specify which core to use. You may also want to take a look at the information in the Multicore Programming part of the NI site.
