"invalid precision value" when inserting into access db
Dear Community,
I am using LabVIEW Data Connectivity Toolkit to insert long text into an access database field of the type "long text". See attached vi.
The error i get is: invalid precision value.
Only 255 charakters can be written to access. After that i get this error.
I have tried:
- creating an access form for my table to avoid inserting data into the table's raw datasheet.
- changing the text format of the access field into "rich text" rather than "text only".
This did not help.
Do I need to search for a solution working with activeX to communicate with access instead of using the DCT?
Thanks in advance!
(2,424 Views)
I can't open your VI because I'm using 2017 (save for 2017 and share if you're still stuck after a while), but have you tried using the old data type of "memo"?
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(2,094 Views)
The NI toolkit itself knows only a very limited number of data types. It assumes, that a string is allways a varchar which ist limited to 255 characters. This might be the reason, why you get an error.
Some ideas:
- build your own SQL insert statement and use DB Tools Execute Query from the advanced palette
- or use another toolkit
- create a child class which corrects this issue
- make your own toolkit
(2,046 Views)
